RedlineShifter Posted June 23, 2012 Posted June 23, 2012 Hey guysIs a there a how2 on how to raise D2 Coilovers? Sorry if this has been brought up before, i just need to raise my glanza asapThanks!! Quote
rinseep82 Posted June 23, 2012 Posted June 23, 2012 Just need two c spanners mate undo the bottom lock nut then wind the spring up using the c spanner on the bottom seat lock if you haven't got any c spanners there's loads on e bay and there cheap inuf Quote
rob_bower Posted June 23, 2012 Posted June 23, 2012 Depending on the coilovers that would adjust the preload for instance on the meisters you can undo the very bottom ring then rotate the strut either raising or lowering depending which way you go without moving the spring seat. Keeping the dampening the same. Quote
RedlineShifter Posted June 24, 2012 Author Posted June 24, 2012 The bottom locking nut wont move. I think it is too tight, is there a way to loosen it? Quote
Taggy Posted June 25, 2012 Posted June 25, 2012 (edited) welcome to hell with D2 coilovers, they are a complete nightmare to adjust once they have been on the car and rusted/covered in gunk. I had to take mine off completly and put them in a vice with a blow torch to heat them up and then whack the collars off. You can get them off just be patient, soak them in parafin over night or some other degreasant.If you want to raise or lower your car never adjust it by the spring, always do it by the collar at the bottom and wind if up or down on the thread as required. If you adjust the preload on the spring it will just cock your suspension up and ruin your ride There are two collars to undo if i remember right, one on the top and the bottom and then you just rotate the whole purple thing around on the thread, you need loads of WD40 in there!Here is mine soaking over night Good luck!! Edited June 25, 2012 by Taggy Quote
Jhandy Posted June 25, 2012 Posted June 25, 2012 (edited) i know this may sound mad, brake fluid dude, leave it to soak on the locking nuts over night, it does work Edited June 25, 2012 by Jhandy Quote
Taggy Posted June 25, 2012 Posted June 25, 2012 Ha ha mine had been on my car for about 4 years!! alot of grime and shit in them Quote
RedlineShifter Posted July 1, 2012 Author Posted July 1, 2012 Thanks for the replies guys. I'll try loosening it when semester break starts. I've already bent two C-Spanners trying! Lol Quote
starletgt.neal Posted September 5, 2012 Posted September 5, 2012 sorry to hijack thread guys but will tein coilovers off an ep82 fit an ep91 they have been sat like this and need new c-spanners so ill soak them in break fluid as above and hopefully they will be ok? just bolt straight onto my ep91? Quote
Bryan-4E-FTE Posted September 8, 2012 Posted September 8, 2012 i guess..My tein coilovers on my glanza are from a EP82. Quote
