Weyro Posted June 27, 2012 Posted June 27, 2012 Im running 1bar on a Ct9, with all supporting mods.Which rpm should i be expecting to reach full boost? Quote
StuDoc 72 Posted June 28, 2012 Posted June 28, 2012 3500-4000 id imagine someone can correct me if im wrong. Quote
Weyro Posted June 28, 2012 Author Posted June 28, 2012 Ok cool, cheersPorted out the wastegate a bit more, so need to adjust the actuator accordingly Quote
bucketep91 Posted June 28, 2012 Posted June 28, 2012 What rpm are u getting full boost just now? Quote
Weyro Posted June 28, 2012 Author Posted June 28, 2012 (edited) Just under 4kIm getting about 0.8-0.85 at 3k Edited June 28, 2012 by Weyro Quote
pick1 Posted June 28, 2012 Posted June 28, 2012 (edited) Is your actuator sticking cuz u should deffo be hitting full Boost before 4k on a ct9 Edited June 28, 2012 by pick1 Quote
Weyro Posted June 28, 2012 Author Posted June 28, 2012 Maybe its just wound out too far. And the exhaust gas is opening the wastegate. Quote
TrisK Posted June 28, 2012 Posted June 28, 2012 Will be a boost leak mateFor sureWill be a boost leak mateFor sure Quote
Max9650 Posted June 28, 2012 Posted June 28, 2012 sounds stupid but whats the best way to see when your hitting full boost? i like to keep my eyes on the road mostly Quote
Weyro Posted June 29, 2012 Author Posted June 29, 2012 i have a HUD that i can change between speed, rpm, boost.Pretty useful , when u dont have some sort of boost leak/dodgey actuator :L Quote
mech5107 Posted June 29, 2012 Posted June 29, 2012 My 2etelu with ct12 hits 0.8bar in 4th in ~3000rpm Quote
Weyro Posted July 1, 2012 Author Posted July 1, 2012 Getting a 1 bar boost at 3k rpm now, just had to adjust actuator Quote
Max9650 Posted July 1, 2012 Posted July 1, 2012 how did you test it? floor it in 1st gear? it sounds stupid i dont really understand it as a starlet idles at say 1200rpm, so your at full boost by 4200?! Quote
AdamB Posted July 1, 2012 Posted July 1, 2012 Test it by going up a hill in 4th gear and watch the rev counter. Quote
Max9650 Posted July 1, 2012 Posted July 1, 2012 my clutch will prob slip haha, okay just boot it at like 2k rpm in a highish gear? cheers Quote
Weyro Posted July 1, 2012 Author Posted July 1, 2012 Yea basically you put it in 4th, and go steady at 2.5k rpm, then floor it, and as the needle is just about to hit 3k look at the boost gauge. Quote
Weyro Posted July 3, 2012 Author Posted July 3, 2012 Success! 1.02 bar at 2500 rpm. Think I'm needing a new actuator spring Quote
Max9650 Posted July 20, 2012 Posted July 20, 2012 Had a go at testing it at 2k RPM , 5th gear WOT and it didnt go full boost ( 0.8bar) until 4.5k revs, went from somthing like 40-100mphThis normal? Quote
