Questions
When one wheel is raised and the other in the floor should it spin freely?
When both wheels are raised when one is rotated should the other go same direction or different ?
I ask because I bought a
Trd mechanical diff
From td04 glanza
Had it fitted and went for mapping. From reading reviews the car should lock and pull with both wheels
However it didn't I nearly ended up in the hard shoulder.
I contacted my gearbox specialist and he says this is not right the diff is either faulty or not as described.
If I am wrong I will apologise for the mistake, if not I want the issue sorting.
It's cost me a hell o a lot of money and time to build my car and don't take kindly to being messed about
Although if I am wrong I will stand correct and sorry awaits
That is all
Dan
Not sure on this diff but some wont lock unless power is being fed too then from the gearbox likewise with both wheels in the air, it may seem like a standard open diff i.e rotating in oposite directions but on the floor both wheels gettin fed power it should lock both or switch between the two powered wheels.
Diffs might also make torque steer worse as of both wheels are locked or switching between the two one might still have better traction say on a half wet road you would get thrown about abit by this!
Well this is what I've read so could be complete b*llox lol
Dan i'm not sure on the mechanical ones but i have a clutch type TRD.
When one front wheel is jacked up it will not spin
When both front wheels are off the floor if you spin one the ones spins in the same direction.
This is how mine acts (OEM LSD)
Edited by Amjad
I would like to get this sorted aswell mate because as i said to yourself it worked very well on track for me and i understand about spending money and wanting results but you were basically telling me its not a lsd yesterday! I will have a good read up on the mechanical diff and see if i can make sence of it!
Thanks,
Allan
