Stefan_s Posted August 2, 2012 Posted August 2, 2012 (edited) i just fitted a td04 turbo kit to my glanza and when i revved it up there was a smel of oil and noticed that there was a slight leak of oil round the oil feed, theres no room to get a spanner into see if the bolt is tight, should i be worried by this or should it be ok? Edited August 2, 2012 by Stefan_s Quote
maddox710 Posted August 2, 2012 Posted August 2, 2012 Use instant gasketX2 just wait for it too cool down and blast some brake cleaner or throttle and carb cleaner to get the oil off Quote
5T4R7ET N/A Posted August 2, 2012 Posted August 2, 2012 have you used a copper washers? you might need new ones Quote
Stefan_s Posted August 2, 2012 Author Posted August 2, 2012 well the turbo kit was a used one so already had the oil feed on top of the turbo attached so i havnt done anything to it, so i dont know Quote
Liam_D Posted August 2, 2012 Posted August 2, 2012 Would defiantly try and get something on it to check it tight mate. Dont want it being starved of oil it needs. Quote
Stefan_s Posted August 2, 2012 Author Posted August 2, 2012 thanks for the advice,just took my car for a small drive to get petrol and checked underneath and theres oil everywhere under the turbo so gonna have to take the radiator off again to tighten the oil feed up and hopefully that should solve the problem Quote
