Guest Enzo Posted August 22, 2012 Posted August 22, 2012 ok a daily ep that ive had for a bit has started showing rust bubles all the way around the rear arches.i bought it like that and intend on fixing it so it doesnt come backcan anyone recomend after sanding down what products to use to make sure the rust doesnt come backthanx in advance for any help or advice given Quote
TrisK Posted August 22, 2012 Posted August 22, 2012 if you sand back to metal mate then get some filer/primer on there so it doesnt oxidize you will be fine Quote
StuDoc 72 Posted August 22, 2012 Posted August 22, 2012 You can use stuff call kurust or jenolite but tbh mate the only way to get rid of it for good is to get into it with a grinder untill its completely gone and then as trisk said just fill it. Quote
rinseep82 Posted August 22, 2012 Posted August 22, 2012 My bodyshop guy uses stuff called gum grinds it all out and puts that in sucks any remaining moisture out the metalwork might b worth a try mate Quote
Ryan-11 Posted August 22, 2012 Posted August 22, 2012 If its pretty bad the only way to get rid is to cut it out, it will just comes back if u grind it and fill it, if its not too bad then you might get away with grinding till it gone. Quote
Guest Enzo Posted August 22, 2012 Posted August 22, 2012 ok bro and peeps thanx for the infoall of it is just surface, think ive cought it in the nic of time.thanx again Quote
StuDoc 72 Posted August 22, 2012 Posted August 22, 2012 Aye just grind and fill then mate youl be sound Quote
akyakapotter Posted August 22, 2012 Posted August 22, 2012 I've always been told to cut it out as it will come back spreads like wild fire rust dose Quote
Starlet__SR Posted August 22, 2012 Posted August 22, 2012 What i've always done with troublesome rust spots is to clear as much of it as possible. Once back to bare metal, coat it with acid etch primer. It helps seal and bonds the paint to the metalwork. Then use your primer/paint of choice to put the colour back.Day Quote
