Ive got a leak coming from the Cam belt side of the Engine.
I tried resealing the sump but no joy.
Im assuming its the crank seal, so was wondering if someone knows where i can get one.
Cheers
Where abouts is the dipstick seal located?
Or do you just mean the rubber seals that are just under the lid/handle of the stick when u remove it from the pipe?
No the pipe that the dipstick goes in. Well further down where that goes in to the engine there could be a leak there im sure its near that side of the engine. Worth a check anyway. Whip off your fan belts then the crank pulley and then timing belt coveres and see if theres oil in there that way u will know if its the crank seal.
Awesome thanks, ill have a look for the dipstick seal. And ill start praying that its that lol.
If it is the crank seal, is this the correct item to buy:
http://www.camskill.co.uk/m19b0s1296p13037/_TOYOTA_STARLET_TURBO_%28EP82_EP91%29_-_SERVICING_PARTS_TUNING_SPARES_and_SERVICE_ACCESSORIES_-_Main_Crank_Seal_-_Cambelt_Side_-_Toyota_Starlet_Turbo_EP82_and_EP91
There is another crank seal available, but it says gearbox side, and is £50!
Thank you for the recommendations guys, that's appreciated.
Gearbox and oil pump side are £40 delivered from us, drop me a PM or give us a call on the number in my sig. These are 100% genuine Toyota too (just like Camskill).
We have them in stock too, ready for same day dispatch via 1st class post.
