just fitted corolla inlet on my sr and......
no but i didnt run it for long. you can smell the coolant in the exhaust gases at the back. whether its still going in the block or not is the thing thats worrying me. i'll get some now, what do you want to see? thanks for the advice by the way guys :friends:
IMG-20120826-00494.jpgbefore
during
when i by passed it the check for leaks at tb
power steering on right ones
bit of water here but been running it without since finding the problem
this was in clouds that meant you couldnt see the back of the car
hmmm not a clue then bud :/ lol
undo the inlet mani bolts and make sure there isnt a water jacket on there, i dont think there is, but just to be on the safe side.
i know when i 1st did mine many moons ago, i put the inlet manifold gasket on backwards meaning it could leak a bit of air in
  On 8/27/2012 at 5:36 PM, PaulStarletSR said:
no wot id do? take it up a B road and kick its cunt in, then go home n see what shes like then.give it a good clear out ;-)
im feeling that way a bit.
could be a head gasket i spose?
