just fitted corolla inlet on my sr and......
oh :( its letting in water from somewhere then. by passed the coolant to the tb totally to check it wasnt getting in at the tb, but still getting lots of steam from exhaust.
no but i didnt run it for long. you can smell the coolant in the exhaust gases at the back. whether its still going in the block or not is the thing thats worrying me. i'll get some now, what do you want to see? thanks for the advice by the way guys :friends:
just ran it again got it a bit warm. turned it off. started it and let it idle which it did then the idle went below usual so swithed off. pics are coming by the way
IMG-20120826-00494.jpgbefore
during
when i by passed it the check for leaks at tb
power steering on right ones
bit of water here but been running it without since finding the problem
this was in clouds that meant you couldnt see the back of the car
hmmm not a clue then bud :/ lol
undo the inlet mani bolts and make sure there isnt a water jacket on there, i dont think there is, but just to be on the safe side.
i know when i 1st did mine many moons ago, i put the inlet manifold gasket on backwards meaning it could leak a bit of air in
did it make it smoke white? theres a fair bit of water forming in the bottom of the backbox on the tip but is this not normal? bit of black in the water too, just soot isnt it?
no it never smoked, probably just condensation in the backbox
but if you have put it on wrong and there is a water jacket, it wont be sealing tidy, so just check that
no wot id do? take it up a B road and kick its cunt in, then go home n see what shes like then.give it a good clear out ;-)
im feeling that way a bit.
could be a head gasket i spose?
