Basicly my car feels like its struggling on idle, it always misses beats like it just jerks and when it jerks the temp gauge jumps up to 3/4 of the way and instantly jumps back down to below half, only does it occasionally but it's almost like it doesn't like idling, it's just so rough, it's been like it for a while, but now today when I put my foot down, the limiter is usually 30 in 1st and 60 in 2nd, but when I hit about 25 in 1st and 50 ish in second, it starts to back fire, it sounds emmense, I wouldent say it's a misfire more the exhaust starts backfiring it weird, but also looses power, so I don't know what it could be, recently the ht leads, spark plugs, dizzy cap and rotor arm have been changed.
And i gave it an oil change about a month ago,
Fuel filter maybe? I've never changed it before.. And I'll change the tb soon with an idle controll valve because mines always idled at 1,400rpm since I bought it like 2 years ago which I know is wrong. Anyone else have any ideas? It's annoying me now :/ it just doesn't like idling
Forgot to say its an ep91 n/a
Edited by DaveyDemolition
Got a quick video today, this was in second going about 45-50mph and i only did it for so long because I wanted to see what would happen, and the whole car just juddered and shook and then cut out completely then started fine straight away, fuel filter I'm thinking? Because like i say I've changed everything else ignition wise, it's fine to drive but this happens whenever I put my foot down a little but, does it in all the gears :/ any ideas?
/>http://i1134.photobucket.com/albums/m603/DaveDemolition/36AF9332-0A79-4A25-9496-1C06D9BF2633-331-00000049BF5970E9.mp4
<a href=&quot;http://s1134.photobucket.com/albums/m603/DaveDemolition/?action=view&current=36AF9332-0A79-4A25-9496-1C06D9BF2633-331-00000049BF5970E9.mp4" target="_blank"><img src=&quot;http://i1134.photobucket.com/albums/m603/DaveDemolition/36AF9332-0A79-4A25-9496-1C06D9BF2633-331-00000049BF5970E9.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Excuse my swearing, it's just really pissing me off :p
I doubt the fuel filter could cause that to happen.. You never know though, try changing it though cause there not expensive. Have you checked your leads / plugs for water?
It doesn't feel like a vacuum leak because I know what that felt like when I had one before, and I'm pretty certain it's not that, but I'll check them anyway, and nah the timing hasn't been done, does it need to be? What about injectors?
get the timing done, you haven't turned the rotor atall? could have advanced/retarded timing maybe? id get that looked at tbh dude, sounds similar what happened to my green n/a, timing was out was cured when it was set right :)
