s there a difference between a jam racing auto ecu compared to a manual one?
will an auto work in a manual and vice versa?
for ep91 by the way.
hat i want to know is,will a AT ecu run ok on a MT car,as ive seen people do auto to manual swaps on standard cars,so im wondering will a jam AT ecu run ok on a MT car.
I don't think an auto ecu will work on a mt. On auto you have kick down and gear shift point. The tps sensors are different between a mt and AT the auto having a 4wire true tps and the MT has a 3 wire on/off type tps
The actual loom that goes to the ECUs is different. One is 2 plug and one is 3 plug IIRC
A GT manual ecu works in a glanza automatic i think
Jay will answer it, IAmLegend knows as he had a JAM ecu in his TD04 auto
Im running an auto ecu on a manual boxed 4age but i started with the auto loom so thats all i had to work with, only thing i had to do was bridge the parking signal as it wouldnt start otherwise.
