clubman s Posted January 28, 2017 Share Posted January 28, 2017 hello, please can you gimme a hand on set it up? need to know wich injectors choose on a TD04L set up, will running a DW pump and with a FMIC cheersAJ Quote Link to post Share on other sites
Gainzy Posted January 28, 2017 Share Posted January 28, 2017 hello, please can you gimme a hand on set it up? need to know wich injectors choose on a TD04L set up, will running a DW pump and with a FMIC cheersAJStocks can handle 1 bar Quote Link to post Share on other sites
olrac911 Posted February 14, 2017 Share Posted February 14, 2017 Hi guys, how many bars of fuel on the FPR to run 1.1 bar of boost? Quote Link to post Share on other sites
5e colin Posted February 14, 2017 Share Posted February 14, 2017 Hi guys, how many bars of fuel on the FPR to run 1.1 bar of boost? probly around 2.8 to 3bar bar ish al depends on acuraccy hope you have a wideband and knock gauge and egt ?? to self tune ?? Quote Link to post Share on other sites
olrac911 Posted February 15, 2017 Share Posted February 15, 2017 Hey thanks for the reply. Is that with the vacuum line connected? I'm still waiting for my wideband. Just preparing everything before I push it to 1.1bar of boost. Quote Link to post Share on other sites
5e colin Posted February 15, 2017 Share Posted February 15, 2017 disconnect it but make sure to block the air feed or your idle will be higher i advise you to run 1 bar only Quote Link to post Share on other sites
