steve-gers Posted September 8, 2012 Posted September 8, 2012 Trying to fit my indiglo dials to my auto EP82 and have so far got them out and the clear face removed but I need to know a couple of things if anyone has some answers I would be very grateful.Question 1Which bulbs do I take out of the clocks (diagram below)?Question 2Do I route the wires from the dial faces in the back of each dial and out a bulb hole? And if so will this not be too much of a bend??I think my answer to question 1 is all bulbs but thought I would confirm 1st. Thanks in advance for any help and the pics are below. Quote
bucketep91 Posted September 8, 2012 Posted September 8, 2012 U dont need to take any out. I fitted mine over the original dails and left the bulbs in. They wont shine through except the odometer, may as well change that for a blue bulb while your at it.Be carefull with the strips there very delicate they should fall into place, dont bemd them. They plug into the transformer you should have got with the kit.Pretty simple job tbh Quote
StuDoc 72 Posted September 8, 2012 Posted September 8, 2012 I was the same I had to take one out for the wires to pass through so that the clear lens would go back on. You wont need A&D so you can remove them and put the wires through there. I jus bent the connection backwards over the dial backing so the wires went in behind do it careful so u dont damage them. As above though you need bulb B for you odometer so leave that one or change for blue lol. Quote
JayJ Posted September 8, 2012 Posted September 8, 2012 Keep the bulbs if you want your needles light up too. You can cut slots to black plastic to get the wires sorted, do it carefully with sharp knife Quote
steve-gers Posted September 8, 2012 Author Posted September 8, 2012 Ok thanks very much just going to wire them up just now can anyone give me some help with that? Quote
StuDoc 72 Posted September 8, 2012 Posted September 8, 2012 Just wire the live into the sidelights on the steering column loom and use an earth there also. 2 min with a multi meter u can suss them out. Quote
steve-gers Posted September 9, 2012 Author Posted September 9, 2012 (edited) Thanks very much to everyone that helped. Got it all done now, everything is spot on except I got the petrol gauge ever so slightly squint I think but hard to notice. Need to cut the plastic a nit to get the wires out as they are out a bulb hole just now and the needles + odometer don't light up. Edited September 9, 2012 by steve-gers Quote
