boostwhore Posted September 11, 2012 Share Posted September 11, 2012 hey guys as above ive got a power fc and the engine light will not go out ive tryed the diag connector but it wont flash up the codes. is it just one of those things that just stay on or do i have to put the old ecu on to get the codes?? cheers Quote Link to post Share on other sites
Socks Posted September 11, 2012 Share Posted September 11, 2012 Mine isnt on...So you have an issue mate.. Quote Link to post Share on other sites
pockrockgtti Posted September 11, 2012 Share Posted September 11, 2012 have you got a hand commander with it? Quote Link to post Share on other sites
boostwhore Posted September 11, 2012 Author Share Posted September 11, 2012 no i havnt got a hand commander. i put the old ecu on it and ran it up. and no fault code were present but pluged back in the power fc and the engine light was stuck on. getting it mapped on thursday will he be able to get the fault code off the ecu then?? Quote Link to post Share on other sites
pockrockgtti Posted September 12, 2012 Share Posted September 12, 2012 Theres no diagnostic codes as such in a power fc at least not like you get on the oem ecu. If you had a hand commander there is an optiin in the menus to do a sensor check. That will give you all the readings from all the sensors and also tell you which ones are connected and unconnected. Does the car start up with the power fc? Quote Link to post Share on other sites
Starbuck Posted September 12, 2012 Share Posted September 12, 2012 Don't the FCs have to be memory cleared before using on another car. As the settings will be different, hence a warning light? Quote Link to post Share on other sites
boostwhore Posted September 12, 2012 Author Share Posted September 12, 2012 cheers guys ive got it booked in for mapping tomorrow so hopefully its just upset because its come from a different vehicle with a different set up. it starts and runs ok but i havnt rly driven it as it needs to be mapped Quote Link to post Share on other sites
