Sefton-EP91 Posted September 16, 2012 Posted September 16, 2012 (edited) I have a 97 glanza and when trying to start from cold but mainly warm the engine takes loads of turns to crank. Then eventually it fires up. The car has a fuel pressure regulator installed but don't know if it is this thats maybe causing the problem. What do you guys think? Thank you. Edited September 16, 2012 by Sefton-EP91 Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 some times mine does this i take the key out lock and unlock the car put key in turn it and it goes straight away dont ask me how but seems to work for me! Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 I find if I switch it off then try again it fires up with a lot less cranking but still more than expected. I brought the car with modifications already installed so I do not know what has been messed around with which is kind of annoying now I have the car. I have a feeling it is a fuelling issue but them I could be wrong. Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 im the same mate i have problems like when i beep my horn my interior light comes on and if im on turbo timer and put my handbrake down engine will cut out lol must be an earth wired to it !! thats the thing they have been tamperd with so much you never know what goes were! Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 Yep see that's half my problem. If I knew what they had touched or messed with then I stand more of a chance sorting it. Could my leads be earthing out or something like that. The previous owner fitted magnicor leads? Or damp plugs? Quote
daniel_g Posted September 16, 2012 Posted September 16, 2012 Think the problem you guys have is the fuel pump not priming properly on ignition / cranking. Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 so would that mean a new fuel pump is in order? Quote
Hawwy Posted September 16, 2012 Posted September 16, 2012 Turbo timer going off with handbrake is wired like that so if its on nobody can steal it and drive it by leep turning the timer up Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 Same questin as jakeep82. Would that then mean new fuel pump? Or could it be resolved with something else? Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 ah thats quite handy never thought of it like that !! Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 Could the problem have anything to do with the fuel pressure regulator? Quote
daniel_g Posted September 16, 2012 Posted September 16, 2012 What pressure is it showing whilst cranking? You will obv need someone to do it so you can read the guage. Try changing the fuel filter first as its prob clogged up, relatively cheap aswell. Just before you go changing the pump. Jake you should know if yours is on its way out now the rear interior is stripped, because it'll be whining its tits off. Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 Thanks mate I'll check it tomorrow whilst at work. I'll also get a fuel filter for it. Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 What should the regulator be showing? I am new to this stuff. Thanks for all the info by the way. It's much appreciated. Quote
micky boy Posted September 16, 2012 Posted September 16, 2012 Think the problem you guys have is the fuel pump not priming properly on ignition / cranking.Was just about to say the same thing Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 So would you suggest a new pump. After I have done the filter obviously Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 mine does whine a bit but then ive never heard one without having the rear stripped lol so wouldnt know what was classes as loud ! Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 http://www.ebay.co.uk/itm/STARLET-1-3-TURBO-EP82-89-95-4E-FTE-ENGINE-FUEL-FILTER-/170692623253?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27be12bb95#ht_1946wt_1139http://www.ebay.co.uk/itm/STARLET-1-3-TURBO-EP91-96-99-4E-FTE-ENGINE-FUEL-FILTER-/170692623254?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27be12bb96#ht_1908wt_1186ep82 and ep91 fuel filters !! Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 http://www.ebay.co.uk/itm/Toyota-Starlet-Turbo-Uprated-Walbro-Fuel-Pump-/270666255345?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f04f74bf1fuel pump Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 Thank you for the links, I'm assuming this pump would be ok to run on my glanza. Quote
jakeep82 Posted September 16, 2012 Posted September 16, 2012 i guess so mate dont quote me on it though Quote
Sefton-EP91 Posted September 16, 2012 Author Posted September 16, 2012 Fair enough mate. It says it will work. There only one way to find out lol Quote
Sefton-EP91 Posted October 24, 2012 Author Posted October 24, 2012 (edited) Old post but thought I would add, I have just recently started to get a noise (crunching/grinding) on start up, it only when I turn the key for engine start whilst engine is turning over, have a feeling it could be starter motor but you guys have any ideas or had something familiar? ThanksThought I would add the starter has never failed to turn on the car.. Edited October 24, 2012 by Sefton-EP91 Quote
Starbo Moorley Posted October 24, 2012 Posted October 24, 2012 Sounds like starter stickin in, check flywheel ring gear too Quote
Sefton-EP91 Posted October 24, 2012 Author Posted October 24, 2012 When you say starter sticking in do you mean it's not fully come out of the housing? Quote
