You dont need to rent mate. Do you not have a car jack? Just jack it up and lie underneath.
Its jus a couple of 10mm bolts that hold the cable in position. Then you remove a heatshield from behind the exhaust and unclip it. Its a doddle bud.
I hadto undo my exhaust to move it but it wasnt a big deal. Took me an hour or something from start to finish.
Yes I have a jack and two axle stands. Should I jack it up from the side or from the rear for the easiest access?
You can jack it up on the rear axle then put the 2 axle stands under the jacking points on the sills at either side at the rear. That way you have even space underneath and no jack to get in your way.
