Im gettin this aswell but its because theres water runnin down the bay n thru 1 of the holes in the bulkhead because the SR is at an angle on stands after havin the glanza engine dropped in.
The loom rubber duznt fit flush in 1 of the holes so thats where mine is cumin from, plus the usual condensation
Mine does this. There's a hole on the bulkhead that the air con pipes used to go through that is usually the cause. Mines the scuttle panel I think though, had it off about a year ago and didn't get it back on properly :p
If you remove the air con evaportaor from inside the car then you can get the bung from toyota for a none air con starlet and seal the hole neatly mine was under £3 for my Glanza.
The water isn't coming in there guys just have a quick look. Carpet is drenched and stinks lol. I pulled aside the wiring in the kick panel and lifted that rubbery shit and the water is coming in between there and the bulkhead. :-\
Its happened quite suddenly like in the last couple of weeks and there's alot of water there today if it was windscreen seal would it not be a more gradual thing?
If it stink its most likely coolant, usually smells almost curry-ish check pipes around heater matrix and the matrix itself. Also whats your coolant level like?
Checked rad and its rammed to the top with water. Its more of a damp smell bro just a bit mouldyish lol. There was a trail of water coming from the mentioned above place not anywhere towards centre console im confuzzled !!
