I ran an EVC 4 for a while was a good controller if a little tricky to setup at times. Much prefer my turbosmart eboost 2 though easy to set up and is a 60mm gauge so has fitted neatly into my pillar pod which is good for changing boost settings i found where i had the evc below the radio it was difficult to see and adjust.
ive the HKS evc 4 and its the best boost controller ive used... its very easy to setup but your turbo must be 100% for the learn mode to function... set the HKS actuator to .6 and do the learn mode on the controller and thats it..... very steady boost control.. have mine for sale on here atm
