Majority of people use 5.1 in their GTs / Glanzas mate, I've always used it in my Starlets too.
We have OEM Toyota 5.1 fluid in stock if you need any.
Regards
Idrees
ID-Workz
Cheers for your contribution lads, only asking because im in the middle of a complete brake overhaul and noticed a nice new bottle of valvoline 5.1 in the the corner of the garage so didnt know whether to stick with dot 4 or flush out and start again with 5.1?
If its only a higher boiling point and there are no gains then i may not bother.
Cheers,
James.
It's also good to remember that there is a big difference with DOT 5 and DOT5.1! DOT5 is silicone based and if you are going to change from/to DOT 5 you should flush the whole system carefully, because silicone won't mix with DOT3, 4 and 5.1 fluids! ;-)
Good info about brake fluids here.
As title says 5.1 not 5.0 I stay away from silicone based brake fluid.
Only asked for input as i have used 5.1 on a majority of cars in the past but i always like to here peoples thoughts before i go ahead with somthing.
5.1 all in now roll on summer :)
Cheers.
Edited by jamesglanza
