2 Options...
1, Plug & Play ECU's pop up between £400-£500 every now and then, that remove all the retrictions of the standard ecu. Simple plug them in and your away!
2, Get a company like Race-Tech or Tuning Developments to Fit and Map a E-Manage Blue onto your car. And map the car to suit what mods and spec your running!
PS Moved your topic into the technical section...
Whilst this topic is up just thought Id ask a question....
With the E manage blue setup ... what is the cost for a re-map if you were to add more mods?
Matt :D
I believe both Race-Tech & TD ovver a emanage and mapped setup for £500-£550
However I believe Ro55ifumi came accross this when he went TD04.... TD charged around the £300 mark where as Race-Tech only charge £100-150 to modify a map they created in the first place...
I'd PM whoever you interested in going to too double check this though...
If your going to stick to a CT9 then go for a plug n play that way you dont need to get it mapped everytime you change something.
