Got.boost Posted November 11, 2012 Posted November 11, 2012 Hi everyone Right I had a rocker cover/inlet/fuel rail laying about so had them powder coated black than I was reading something on a forum and people having wheels powder costed then they where cracking but now thinking is any of the bits I have had done going crack Has anyone ever had any bits the same as mine powder costed and have they ever cracked Thanks Quote
abbott Posted November 11, 2012 Posted November 11, 2012 Mate i get alot of powder coating done for people and never had any think crack. The one thing if you have had the bits you have had done and anythink engine related is to make sure they have not ahot blasted the inner of the rocker cover if so clean it out good and proper other wise your engine will have sand round it which will block oil ways pump etc. clean inlet and fuel rail out to brake cleaner is good to wash out with but make sure its done well Hope this helps Quote
Rob H@RCH Engineering Posted November 11, 2012 Posted November 11, 2012 I have never heard of powder coating cracking, I have had loads of stuff done over the years for my V8s and stuff for the starlet including the wheels and never had any problems. Quote
daniel_g Posted November 11, 2012 Posted November 11, 2012 Should be fine dude. Thing with the wheels was people had them done in places where they weren't doing it properly, in the way they were cooling down iirc. I'm just gonna use some VHT paint to do mine. Quote
Got.boost Posted November 11, 2012 Author Posted November 11, 2012 Thanks alot guys and don't worry all the in sides of all the bits where all masked up when doing it but will get the brake cleaner and a air line out and give them a good clean Thanks Quote
StarletMad Posted November 11, 2012 Posted November 11, 2012 The piece to be coated should be left to soak in a chemical solution (mild acid) for 20 minutes at around 55 degrees so should cleanit pretty good. Powdercoat is extremely durable it should not crack... Quote
