Hawwy Posted November 18, 2012 Author Share Posted November 18, 2012 (edited) your wrong mickey. 100s of turbos are not water cooled! Just loop the pipe and dont need to block off the holes on the turbo, just leave them open.Really can just leave them open?can i use vacuum hose for looping it. ? If not what type of pipe can i use Edited November 18, 2012 by Hawwy Quote Link to post Share on other sites
keirz Posted November 18, 2012 Share Posted November 18, 2012 they wasn't destined to be on a starlet though. Some similar sized td series turbos dont have water lines. Depends on the engine set up as well as the turbo design. Im not saying your wrong that it would be good to use them, i would use them personally but its not that essential. Quote Link to post Share on other sites
keirz Posted November 18, 2012 Share Posted November 18, 2012 the ones on the turbo yes. Its just an empty chamber surrounding the housing. If nothing is going into it nothing will come out of it! Quote Link to post Share on other sites
keirz Posted November 18, 2012 Share Posted November 18, 2012 (edited) the ones on the turbo yes. Its just an empty chamber surrounding the housing. If nothing is going into it nothing will come out of it! I use fuel pipe to make my water lines Edited November 18, 2012 by keirz Quote Link to post Share on other sites
5T4R7ET N/A Posted November 18, 2012 Share Posted November 18, 2012 I think the size of the bolt of the water line being 17mm?? can someone confirm,it needs to be short so you will need to cut the bolt.a lot of people dont run water lines with td04, its tried and tested. i guess its up to you. Quote Link to post Share on other sites
Hawwy Posted November 18, 2012 Author Share Posted November 18, 2012 So can i loop with vacuum hose yes or no? Quote Link to post Share on other sites
micky boy Posted November 18, 2012 Share Posted November 18, 2012 Corded rubber hose would be best mate dont use blue silion hose it might split and you could lose your water without knowing it! Quote Link to post Share on other sites
Hawwy Posted November 18, 2012 Author Share Posted November 18, 2012 Like so :/>http://item.mobileweb.ebay.co.uk/viewitem?itemId=140644519892&index=0&nav=SEARCH&nid=48546972858Becauae vacuum hose supposedly cn tak up to 180deg c Quote Link to post Share on other sites
micky boy Posted November 18, 2012 Share Posted November 18, 2012 Yeah thats corded hose so will be fine mate Quote Link to post Share on other sites
Hawwy Posted November 18, 2012 Author Share Posted November 18, 2012 How much mm u think the hole is on the feed&return on the block Quote Link to post Share on other sites
A L 3 X Posted November 19, 2012 Share Posted November 19, 2012 At a guess mate I think it's about 7mm but don't quote me Quote Link to post Share on other sites
