stucat87 Posted November 26, 2012 Share Posted November 26, 2012 Aright folks just wandering what fittings I'd need for turning my rocker head into race spec head with this catch can. />http://www.ukstarletowners.com/index.php?showtopic=58263&view=&hl=&fromsearch=1. I've got rocker cleaned and need fittings to weld on top and fitting for the catch can side of the braided lines? Also need the lines but they can come after I know what fittings to use? Can anyone tell me ??? Thanks Quote Link to post Share on other sites
turbo Grant Posted November 26, 2012 Share Posted November 26, 2012 If you measure the id of the hose you have then you can work out what size fittings you need. Most people use -8 or -10 fittings. You could probs get away with using push on fitting if they are the same size as the hose your using Quote Link to post Share on other sites
stucat87 Posted November 26, 2012 Author Share Posted November 26, 2012 Wel I haven't got hoses yet. The fittings on the catch can are -8 so will get that size pipes but I need the fitting for top of rocker and ones to go on end of pipes. And not sure wat they need to be like. Quote Link to post Share on other sites
JayJ Posted November 26, 2012 Share Posted November 26, 2012 For rocker cover an-8 bungs and hose fittings and hose to catch can fittings. And remember that the more you pay the better the quality is. Those aren't the best ones, but you get the idea what to look for. :-) Quote Link to post Share on other sites
stucat87 Posted November 26, 2012 Author Share Posted November 26, 2012 That's superb mate. Think ill need to change the fittings in my catch can as the ones I have aren't screw type. And think ill be getting brass fittings for it as my dad used to run a company that makes hose and fittings, so can get them cheap there. Also think the goldie look would look quite good Quote Link to post Share on other sites
yaristurbo Posted November 26, 2012 Share Posted November 26, 2012 For rocker cover an-8 bungs and hose fittings and hose to catch can fittings. And remember that the more you pay the better the quality is. Those aren't the best ones, but you get the idea what to look for. :-)What hose would be needed Quote Link to post Share on other sites
stucat87 Posted November 26, 2012 Author Share Posted November 26, 2012 The braided hoses that go from the rocker to the catch can, and return Quote Link to post Share on other sites
Dean @RW-Developments Posted November 26, 2012 Share Posted November 26, 2012 Let me know if you get stuck! I can supply and weld male fittings if needed Dean Quote Link to post Share on other sites
JayJ Posted November 27, 2012 Share Posted November 27, 2012 What hose would be neededBraided AN-8 hose like this or nylon one, if you need flexibility. Quote Link to post Share on other sites
