_shaun_ Posted November 27, 2012 Posted November 27, 2012 would realy like to take up welding for the odd brackets and such for my car but dont want to sink a pile of money into a welder to barely use. anyone picked up good mig welders for a nice price? or any tips of welders to avoid?cheers shaun Quote
StuDoc 72 Posted November 27, 2012 Posted November 27, 2012 Sometime a wonder about you boy!! lol its just a matter of practicing with welding the more you do the better you will get. I used to do it in ma old work but cudnt tell u kit details I just worked with what I was given. Quote
_shaun_ Posted November 27, 2012 Author Posted November 27, 2012 aye i have a talent for making this build take longer than i planed thats the plan if i can find a good cheap welder i can just practise will only be for little bits and bobs on the car but think it would be realy handy. Quote
turbo Grant Posted November 27, 2012 Posted November 27, 2012 Some thing like this in eBay will do the job. Just an item number 170911590664 Quote
_shaun_ Posted November 27, 2012 Author Posted November 27, 2012 ahhh so just a cheapy ebay unit do the job u think of anything to stay clear off when am getting one? Quote
turbo Grant Posted November 27, 2012 Posted November 27, 2012 That's just the sort of thing you want to get. Best to go for a sip or clack some thing branded ideally. They are good welders for hobby use. Even the gas-less ones do a good job. But then your limited to what wire you can use and the wire is pricey. Quote
_shaun_ Posted November 27, 2012 Author Posted November 27, 2012 been tempted by this http://www.amazon.co.uk/Wolf-MIG-Combination-Welder-Comprehensive/dp/B004D45NWY/ref=pd_rhf_gw_p_t_1 then i can use the gas aswell if needed the misses was asking what i wanted for xmas might see if she will get me a welder lol Quote
starletburkie Posted November 27, 2012 Posted November 27, 2012 bare in mind the types of metal you will be welding! Quote
Dean @RW-Developments Posted November 27, 2012 Posted November 27, 2012 Better to get a gas mig! Welding with the flus wire ain't the best I have a sip mig and tbh it's not bat at all! It's all about the tig welded for me though Dean Quote
yaristurbo Posted November 27, 2012 Posted November 27, 2012 I love to start tig but its the investment for hobby use is alot Quote
turbo Grant Posted November 27, 2012 Posted November 27, 2012 That welder you put in the link should do the job. It uses gas and if your welding outside with wind then you can use the gasless wire Quote
starletburkie Posted November 27, 2012 Posted November 27, 2012 all about tig and stick welding for me so next investment is a ac/dc tig and arc welder Quote
Stu Posted November 28, 2012 Posted November 28, 2012 For thin panel steel a mig is probably better as it doesn't push so much heat into the steel and you can spot weld quite easily. Not sure what you guys have over there in the way of for sale websites but you should be able to pick up a small machine fairly cheaply. Avoid gasless welding like the plague and I'd suggest using Argoshield gas which will give you a nicer weld than CO2 but is slightly more expensive. Those disposable bottles are ok for really small work but dissapear very quickly if your laying down longer welds that require more flow - probably best to get a small D size bottle on rental.Brand wise my machines are Unimig and Lincoln Electric. My ACDC tig is a Lincoln inverter 205amp and I've used alot of different machines over the years and its by far the best. For home/garage work I'd try and pick up a second hand good name machine rather than the cheaper new chinese stuff as the quality just isn't there.Another option is just hiring a machine which can actually work out to be a cost effective way of doing things - get all your plates etc ready then hire a welder for a weekend? Quote
james@cjperformance Posted November 28, 2012 Posted November 28, 2012 steer clear of sip hobby migs they are shite. the wire feeds fail on them and the speed controller is pretty much non existant.if you just want something to do a few welds and just dick about with go for something like a clarke 160en they are a little more expensive but are good value for money.id go for a gas welder to although most clarke welders allow you to use bot tyoes of wire.m Quote
turbo Grant Posted November 28, 2012 Posted November 28, 2012 I've used a few sip welders and they are fine for the odd job. I've welded a whole inner and outer sill on an old metro using a sip gasless. With welders you pay for what you get tho. Quote
Dean @RW-Developments Posted November 28, 2012 Posted November 28, 2012 I've got a desent sip welder and it works fine done loads of sills etc Quote
scottyb Posted November 28, 2012 Posted November 28, 2012 i wish i could weld, id love a project car to work on entirely all my self but its the costs involved that i cant handle Quote
turbo Grant Posted November 28, 2012 Posted November 28, 2012 You looking 600£ pluss for a tig set up Quote
yaristurbo Posted January 30, 2014 Posted January 30, 2014 any one got a link to a good starter tig welder Quote
kavan-k Posted January 30, 2014 Posted January 30, 2014 Tig is beast, but your just starting out so I wouldnt recommend that at all! Gas/gasless mig is a good starter. I prefer stick welding but thats because I was taught on one lol. Mig welding is piss easy too! You can get a sealey mig for decent money and they are a cracker welder Quote
kavan-k Posted January 30, 2014 Posted January 30, 2014 http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=390196348991 Quote
yaristurbo Posted January 30, 2014 Posted January 30, 2014 ive been mig welding for a while, just fancy abit of tig Quote
kavan-k Posted January 30, 2014 Posted January 30, 2014 Try a miller diversion 165, looks to be a good starter kit, not got a tonne of features but if your just looking to mess around with it you wont need them anyway! Tigs are expensive lol Quote
Stu Posted January 30, 2014 Posted January 30, 2014 Millers are a really good brand, up there with Lincoln Electric etc Quote
