Hawwy Posted November 28, 2012 Posted November 28, 2012 As title Says when driving it jerks sometimes feels like the same as constantly tapping gas pedal when drivingCheers Quote
pick1 Posted November 28, 2012 Posted November 28, 2012 U checked your leads and plugs n dizzy sounds like its miss firing Quote
Hawwy Posted November 28, 2012 Author Posted November 28, 2012 Think am going to try plugs now doesnt do it warm i dont think Quote
pick1 Posted November 28, 2012 Posted November 28, 2012 Change the plugs if u know some one that god a decent set swap em over n see if that cures the problem Quote
pick1 Posted November 28, 2012 Posted November 28, 2012 To me it doesn't look to bad mate but some one else may correct me if all plugs are ok then check your leads mate Quote
A L 3 X Posted November 28, 2012 Posted November 28, 2012 Do you have an Ebc? Sometimes if you feather the throttle the boost can be a bit jerky at high revs but your issue sounds completely different lol... Quote
Hawwy Posted November 28, 2012 Author Posted November 28, 2012 All plugs are similar to one in the picHow am i meantto check leads It feels like its feathering the throttle but i just drove normal Quote
Amjad Posted November 28, 2012 Posted November 28, 2012 Sounds like a plugs issue, is there water down there? My 3rd plug was wet and it was doing this Quote
Hawwy Posted November 28, 2012 Author Posted November 28, 2012 No all dry just carboned up a bit Quote
Lawless Posted November 28, 2012 Posted November 28, 2012 I had this problem and it was a hairline crack on the spark plug on the white plastic piece causing it to misfire might be the problem Quote
ryan lang Posted November 28, 2012 Posted November 28, 2012 mines doing the exact same, and now the misfire is doing it while cruising too. ive checked my plugs today and they were fineshould be getting some new leads to try next aswell Quote
dai_starletN/A Posted November 29, 2012 Posted November 29, 2012 funny enough im getting the same issue until i get to 50+mph then its fine. weird? Quote
dai_starletN/A Posted November 29, 2012 Posted November 29, 2012 Thinks its cold weatheryeah i think so too ive stopped driving it now till it gets a little warmer then i'll check whats up Quote
ryan lang Posted November 29, 2012 Posted November 29, 2012 mines turned out to be a broken connection for the ecu power wire to my FCD lol Quote
TurboTobz Posted January 19, 2013 Posted January 19, 2013 Mine does this when it begins to struggle as revs get low and im off the throttle I think it's something to do with a vac leak/maybe icv or similar Quote
