Azz Posted November 28, 2012 Posted November 28, 2012 Can someone tell me best way to stop the crank pulley turning whilst trying to undo the bolt that holds it in place?(Drivers side lower pulley)Thanks ladsAaron Quote
StuDoc 72 Posted November 28, 2012 Posted November 28, 2012 Put it in gear and foot on the brakes. Quote
Azz Posted November 28, 2012 Author Posted November 28, 2012 Put it in gear and foot on the brakes.Thats what ive tried so far but it still turns so far things springs back.Doesnt lock the pulley so it wont undo :/anymore advice guys Quote
H_D Posted November 28, 2012 Posted November 28, 2012 U need a harmonic pulley puller do not try to pry it out or do not hit it with a hammer from the back,http://www.machinemart.co.uk/shop/product/details/cht223-46-pce-harmonic-balance-puller Quote
Azz Posted November 28, 2012 Author Posted November 28, 2012 U need a harmonic pulley puller do not try to pry it out or do not hit it with a hammer from the back,http://www.machinema...-balance-pullerNot got to that as yet mate as im stuck trying to get the center bolt off, thats my problem so far Quote
H_D Posted November 28, 2012 Posted November 28, 2012 (edited) That bolt can be a right bitch to remove i think they are ment to be torqued down at 155nm iirc.My mate had this issue recently and what he did was remove 1 of his spark plugs and put a rope down the spark plug bore and he mananged to get it trapped inside the engine so it cannot cannot turn and it worked..I personally would not reccomend this tho Edited November 28, 2012 by H_D Quote
Azz Posted November 28, 2012 Author Posted November 28, 2012 is the engine out of the car?No, its still in the car but Ive lowered the engine far enough down to work on it Quote
StuDoc 72 Posted November 28, 2012 Posted November 28, 2012 (edited) Ok well your gna need a buzz gun then. Did you have the passenger side wheel on the deck when you were doing so?It just takes some persistance and send a bit of shock through the bolt as it will be very tight to stop the engine undoing itself.If you have both drive shafts still in place and the gearbox is all intact then gear and brakes should have locked it I find that strange unless your clutch is slipping. Edited November 28, 2012 by StuDoc 72 Quote
Azz Posted November 28, 2012 Author Posted November 28, 2012 Ok well your gna need a buzz gun then. Did you have the passenger side wheel on the deck when you were doing so?It just takes some persistance and send a bit of shock through the bolt as it will be very tight to stop the engine undoing itself.If you have both drive shafts still in place and the gearbox is all intact then gear and brakes should have locked it I find that strange unless your clutch is slipping.Yes both wheels are on the ground thats what i thought it should stop the crank turning but its not doing, never had a problem with my cluth slipping either so im abit confused at the minuteThat bolt can be a right bitch to remove i think they are ment to be torqued down at 155nm iirc.My mate had this issue recently and what he did was remove 1 of his spark plugs and put a rope down the spark plug bore and he mananged to get it trapped inside the engine so it cannot cannot turn and it worked..I personally would not reccomend this thoI will pass on this one if you dont mind, dont like the idea of putting stuff down my engine other then plugs haha Quote
StuDoc 72 Posted November 28, 2012 Posted November 28, 2012 If they are torqued to 155NM then it shouldn't be hard to come off 155 isn't very tight at all. Its more to do with the time its been on for the heat of the engine and the fact the engine turns when its on.Try a buzz gun buddy if that fails you will need some oxy acetylene to heat it up. Quote
Azz Posted November 28, 2012 Author Posted November 28, 2012 If they are torqued to 155NM then it shouldn't be hard to come off 155 isn't very tight at all. Its more to do with the time its been on for the heat of the engine and the fact the engine turns when its on.Try a buzz gun buddy if that fails you will need some oxy acetylene to heat it up.Thanks for the advise matey, just managed to get it off now.1st gear didnt do it so tryed 2nd with more force and got itCHeers fellas Quote
StuDoc 72 Posted November 28, 2012 Posted November 28, 2012 I should have said never to use 1st gear lol.Good stuff glad you got it buddy. Quote
Flaminsam Posted November 29, 2012 Posted November 29, 2012 Or you can be dangerous like me. Get a 2ft strong arm with a socket on the bolt (19mm iirc?) then get a assistant to flick the engine over on the starter motor while holding the bar against the floor. That's how I did charls on my drive before I got my lock up. Quote
Azz Posted November 29, 2012 Author Posted November 29, 2012 Or you can be dangerous like me. Get a 2ft strong arm with a socket on the bolt (19mm iirc?) then get a assistant to flick the engine over on the starter motor while holding the bar against the floor. That's how I did charls on my drive before I got my lock up. haha brave but not a bad idea i suppose.You dont by anychane know if you have to take the oil pump off to get to the crank seal or just the pulley on the oil pump itself do you ?Cheers aaron Quote
Flaminsam Posted November 29, 2012 Posted November 29, 2012 Unfortnately the oil seal is fitted into the oil pump assembly. So its quite a involved job really. Need to take bottom timing pulley off too, they can be tight! Quote
Azz Posted November 29, 2012 Author Posted November 29, 2012 All sorted and back togeather thanks for the help gents Quote
micky boy Posted November 29, 2012 Posted November 29, 2012 (edited) You could of do with something like this!http://www.bearingpu...jaw-puller.htmlGlad you got it sorted anyways dude Edited November 29, 2012 by micky boy Quote
