Azz Posted December 5, 2012 Posted December 5, 2012 Oil pressure and temp go into the sandwich plate Quote
Hawwy Posted December 5, 2012 Posted December 5, 2012 Okay as ive hears before sandwich plate dont fit properly Quote
Banbury Glanza Posted December 5, 2012 Author Posted December 5, 2012 I can buy an oil pressure with all the stuff to go with it yea ? Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 Okay as ive hears before sandwich plate dont fit properlyThe sandwich plate should fit fine mateI can buy an oil pressure with all the stuff to go with it yea ?you can indeed mate Quote
AdamB Posted December 5, 2012 Posted December 5, 2012 (edited) If you buy an oil pressure gauge, it SHOULD come with all the necessary fittings to have a complete working gauge. Although you may need a sandwich plate.Some people T the oil pressure switch on the front of the block as it saves grinding the power steering bracket.I've got some STRI gauges and love them Edited December 5, 2012 by AdamB Quote
Azz Posted December 5, 2012 Posted December 5, 2012 (edited) Rite il put it all in one post for you buddy Water temp adapter - fits into rad pipes or you can buy adapter from rhd japan that goes in the side of the water pump which your sensor screws in Sandwich plate - goes between block and filter, you will need to either grind the sandwich plate or the power steering bracket a little to make it fit ( I did sandwich plate ) Sensors - all sensors will come will the gauges Oil temp into - sandwich plate Oil pressure into sandwich plate Water temp into - rad pipe/black adapter You will need to buy the adapters as they are not supplied with the gauges Hope this clears everything up buddy Edited December 5, 2012 by Azz Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 I've got some STRI gauges and love them what series have you got mate? Quote
Liam_D Posted December 5, 2012 Posted December 5, 2012 Rite il put it all in one post for you buddy Water temp adapter - fits into rad pipes or you can buy adapter from rhd japan that goes in the side of the water pump which your sensor screws in Sandwich plate - goes between block and filter, you will need to either grind the sandwich plate or the power steering bracket a little to make it fit ( I did sandwich plate ) Sensors - all sensors will come will the gauges Oil temp into - sandwich plate Oil pressure into sandwich plate Water temp into - rad pipe/black adapter You will need to buy the adapters as they are not supplied with the gauges Hope this clears everything up buddySpot on advice! That's exactly how mine are installed! Sandwich plates are avalible through idworkz! Quote
AdamB Posted December 6, 2012 Posted December 6, 2012 what series have you got mate?Got the DSD SLM ghost face series mate. I might talk to Mike and see if I can swap them because mine light up amber and would probably prefer light up white lol.I got Oil pressure, oil temp, water temp and volts, but going to get rid of the volts one and get boost Quote
Mike@TD.co.uk Posted December 6, 2012 Posted December 6, 2012 I would suggest:Water TempOil TempOil PressureBoostWe have water temp sensor adaptors and sandwich plates here also.If you want all 4, give me a shout and we'll sort something out ;)CheersMike JonesTuning Developments Ltd Quote
Banbury Glanza Posted December 6, 2012 Author Posted December 6, 2012 Cheers mike will be in contact soon need a few other bits as well Quote
Mike@TD.co.uk Posted December 6, 2012 Posted December 6, 2012 No problem Todd CheersMike JonesTuning Developments Ltd Quote
