Weyro Posted December 14, 2012 Posted December 14, 2012 (edited) Wondering if anyone can tell me how to reset the base idle using the idle screw, is it simply a case of turning the screw all the way back then resetting the ECU?CheersEDIT: Which way do you turn it to turn idle down, cant check as the battery is disconnected Edited December 14, 2012 by Weyro Quote
JayJ Posted December 14, 2012 Posted December 14, 2012 Start the engine and let it warm up to normal temp. Short circuit TE1 and E1 pins from the diagnostic plug and then turn the idle screw counter-clockwise to decrease idle RPMs. Quote
Xpect Posted December 14, 2012 Posted December 14, 2012 to reset the ECU to base settings (albeit also everything else electronical in the car) you can just unplug the ground of the battery for like 5 minutes.After that it will learn whatever small things you did to the engine in like 400-700km of driving. Quote
JayJ Posted December 14, 2012 Posted December 14, 2012 Or remove the ECU fuse, so you don't have to set your clock/radio/player again. Quote
Xpect Posted December 14, 2012 Posted December 14, 2012 Would be the better solution, you're right. Quote
Weyro Posted December 14, 2012 Author Posted December 14, 2012 cool thanks, which one is the ecu fuse? Quote
Weyro Posted December 14, 2012 Author Posted December 14, 2012 turns out its clockwise to lower lol Quote
JayJ Posted December 14, 2012 Posted December 14, 2012 Haha, was wondering if it was clockwise though. There should be layout inside the fuse cover, fuse should be small 10A or 15A Quote
Weyro Posted December 14, 2012 Author Posted December 14, 2012 Is it the engine bay fusebox or under the steering wheel? My engine bay one doesnt have a diagram Quote
turbo Grant Posted December 14, 2012 Posted December 14, 2012 Or umplug the ecu behind the glove box Quote
JayJ Posted December 14, 2012 Posted December 14, 2012 www.toyotagtturbo.com/wiki/ep91fuses/ep91underhoodfuseboxmain.jpg there you go Quote
Liam_D Posted December 15, 2012 Posted December 15, 2012 I would normally unplug the ECU to do this too! Quote
EP-Azz Posted January 8, 2013 Posted January 8, 2013 Is this the same on my glanza lee? Tickover is too low for my lking lol Quote
