Leave window rubber in and run a bead on it then shut the window?? or just run it around the outside with window closed.
Cant think of any better ideas.
Cant believe more people dont have this issue... my window pully tooey things are shite. Does everyone elses just pull to or do they lock down??
If the rubber ok then Its properly window pulley thing thats the problem to lose they should lock down change it or if u cnt get 1 try one off another car should be sorta the same unless Its fixed to the window
I have this problem, but i haven't got around to fixing it yet. Was gonna get poly windows and seal them in.
But if you are using it daily id fix it asap, the way you suggested first.
'Leave window rubber in and run a bead on it then shut the window'
Edited by daniel_g
