whitestar Posted January 14, 2013 Posted January 14, 2013 What is this sensor on intake pipe and is it needed when relocating air filter? If not, what do I do with the vac lines and the connector after relocation? Quote
jellybaby Posted January 14, 2013 Posted January 14, 2013 For air con mate I got rid of mine when relocated mine and just blocked off the vac pipe with a screw just before the inlet Quote
whitestar Posted January 14, 2013 Author Posted January 14, 2013 Are you sure? Blocking sounds a bit harsh. I guess I'll just remove the pipe and let the thing hang free or cable tie it somewhere. Does anyone know what it's for exactly? Quote
Flaminsam Posted January 14, 2013 Posted January 14, 2013 Its for your carbon canister. Your not allowed to vent gas from your fuel tank to atmosphere, so the carbon canister catches any hydrocarbons from your tank. Quote
whitestar Posted January 14, 2013 Author Posted January 14, 2013 (edited) Ok thanks! Good to know! I'll just leave it hanging then. Edited January 14, 2013 by whitestar Quote
corofin12345 Posted January 14, 2013 Posted January 14, 2013 you can remove it if ya want.. its not important.. if ya do, just bung the pipe on throttle body after... near all remove this when cleaning up the bay Quote
