steviet Posted January 17, 2013 Posted January 17, 2013 Anyone know of hand the uk battery code for ep82 ? Cheers Stevie Quote
H_D Posted January 17, 2013 Posted January 17, 2013 You can get a replacement battery from halfords. The part number is hb038 you will also need bigger connectors for the terminals on that battery. Quote
steviet Posted January 17, 2013 Author Posted January 17, 2013 Cheers, I take it that the ep82 & ep91 have the same batteries ? Quote
daniel_g Posted January 17, 2013 Posted January 17, 2013 Another alternative, if you still have the import size terminals then a hyundai I10 battery works as it uses the import size, and its really small. Only issue might be the battery tray but im sure you can secure it somehow. Quote
Neo Gold Posted January 17, 2013 Posted January 17, 2013 What APH rating is that battery please? Quote
Neo Gold Posted January 17, 2013 Posted January 17, 2013 Ah...found it...35AH & i already have a Yuasa fitted to mine the same AH rating...could do with a 45 AH tbh.These clifford alarms are greedy & the car cannot be left more than 4 days or so...it depleats.... Quote
