Going to get a front antirollbar an I don't know which I should get. I was thinking 24 but any experience would e much appreshiated.
Regards
I've been told to steer clear of bigger front anti roll bar as It will make it under steer and as the one that's on there works very well I would probly just replace the bushes and blow money else where
People always say that but I don't find my car understeers much
I should also add I was running Poly bushes on the stock ARB before and the improvement was huge using a Whiteline 24mm
@Amjad your noy drivin hard enough man lol.
Alot depends on how much you tighten the arb to the wishbones.
Tighten them up to give understear in the dry and loosen to encourage oversteer in the wet.
Id rather have predictable understeer than oversteer. Im a very fastroad driver and not a trackday hero
like adam said its abouy personal preference and needs. Are you trying to balance.your car.or.just.on the qurst to go faster? What have you so far man, Id put the front arb down the list behind rear parts, good tyres, wider wheels stiffer shocks,
My cornering speeds wemt from 40mph to 85mph with the whiteline rear parts and fresh front bushes on a oem arb same as.amjad
Four tyres.the.same is important
I have meister r coilovers and will be fully poly bushed with anti lift kit. I will get the rear at the same time so there isn't much else I can get lol.
I drove it to and past the limit on track, and found it oversteered :)
