Danza V Posted February 16, 2013 Posted February 16, 2013 Hey all as a bove after a air filter relocation... Replaced the PCV.. Checked all vac lines, Bypassed the icv to cancel that out.. but it still does this, its intermittent at times and will stop and idle ok then will go back to jumping like mad in park.. I do have a exhaust leak from my felxi but i mean i would think it would cause high idle yes but not jumping?? Quote
Danza V Posted February 20, 2013 Author Posted February 20, 2013 Bump. Anyone? Driving me mental now! I checked my bov last night and cleaned if out and made no difference. Checked my air filter piping also- no difference, cleaned throttle butterfly and cleaned inside- no change , pcv also rechecked and icv checked above.. Checked the cable and it seems fine. Just to give you an idea, when im driving and start up it goes straight to 1800 on cold and when driving and I slightly press the throttle it will shoot up quite quickly by a couple of 100 rpm and when you let off it will jump like mad and j mean very aggressively!! But when I got tj work the idle went to 1400rpm as z opposed to a usual 2000 rpm, it's like it fluctuates... Please help!!! Quote
T-dog Posted February 20, 2013 Posted February 20, 2013 I had a very similar problem the other week and it was down to the ignition timing and tps sensor not being set right , maybe try them Toby Quote
Danza V Posted February 20, 2013 Author Posted February 20, 2013 Cheers for replying mate How did you rectify it bud? Did yours start doing it out of nowhere? Quote
Spoon_tuned Posted February 22, 2013 Posted February 22, 2013 Do you have a split pipe anywhere? From breather pipes. Also iacv?? Sounds stupid but my honda used to hunt and idle was high sometimes but i bled the water system. And afterwards idle was so much better could be worth a try. Quote
T-dog Posted February 22, 2013 Posted February 22, 2013 Cheers for replying mate How did you rectify it bud? Did yours start doing it out of nowhere?. I just set them by using the how to threads on tggt , yeah it just idle high on start up and you used to hunt when I would be at traffic light or stop for a few seconds in netraul Toby Quote
Danza V Posted February 22, 2013 Author Posted February 22, 2013 Cheers mate, il have a look at doing that.. Quote
Danza V Posted February 22, 2013 Author Posted February 22, 2013 Been told that my timing and map sensor may not fix it...update though!! Now has a slight misfire and revs drop, leads , dizzy and arm you think? Plugs are new Quote
