jake44 Posted February 21, 2013 Posted February 21, 2013 hi all, i got in the glanza this morning and did the usual, let it warm up a bit, and me warm up a bit. then went to drive away. The brake pedal felt really stiff, like there was no servo? started to ease off at point but then would come back? any body had this before? Oh and the clutch pedal felt a bit stiff too cheers guys Quote
Danza V Posted February 21, 2013 Posted February 21, 2013 Clutch could be on way out if its heavey or stiff.. Test the servo by pumping the pedal before starting the car and hold down the brake pedal then start it up if it sinks then the servo is working .. Sticky caliper piston ? ... Some people may have more experience Quote
StuDoc 72 Posted February 21, 2013 Posted February 21, 2013 ^^^^ This. Nah man your right pump up the pedal if it sinks a bit when u start the engine its good. Or you can pump the pedal when its on and see if the revs flutter too. I dont think a sticky piston would cause a stiff pedal as the rest of the pistons would still push out so you would just have shit brakes. Was it especially cold this morning? What about your fluid? When did you last change it? May have absorbed moisture and slightly frozen if its really old. The servo could be weak too I guess sounds like a funny one. One of those have to diagnose it in person kinda 1s. Quote
jake44 Posted February 21, 2013 Author Posted February 21, 2013 yeah ill have to have a look down at the workshop at the weekend, yeah it was cold, seemed as if it might be abit too cold as it eased as i was driving, Quote
Keri-WMS Posted February 21, 2013 Posted February 21, 2013 Depending on the pedal box design (I've not looked at them very closely!!!) if the pedals share a common shaft and both pedals are suddenly stiff, I would just take a peek at the shaft / bushes etc? Quote
Liam_D Posted February 23, 2013 Posted February 23, 2013 My clutch pedal did this once, drove a few miles and then it eased off. Never done it since? The joys of Starlet ownership... Quote
