So I have setup like this on my glanza:
Stock internals
Stock CT9
Stock mani ported
decat
fujitsubo Powergetter
HKS actuator
Blitz dump
Apexi air filter
Iridium plugs with ultra leads
removed boost restriction
JAM ecu
AEM AFR
Depo boost gauge
I'm going to up the boost to 1 bar. Do I REALLY need a fuel pressure regulator? I have my AFR gauge so I can see all the time if it's lean or not. I was told that stock fuel pump should be enough for that kind of setup and power it will produce.
The engine is healthy and in good shape.
And is it recommended to up the boost gradually or should I wind it up to 1 bar straight away?
Personally I would wind it up to a bar, reset the ECU, run it in again at a bar and watch your AFR gauge.
FPR isn't necessarily needed at that level
