whitestar Posted February 26, 2013 Posted February 26, 2013 I'm about to install my AFR soon. I have two bungs welded on my jperformance decat and I'm planning to use the upper for the stock sensor and the lower for the bosch one that came with the gauge. The installation guide tells that the sensor should be mounted 36 inches down stream if it's been run on a turbo charged engine and 18 inches if on a NA engine. Does it matter if I install it to the lower bung and it's not quite 36" away? I assume that it can only affect to the life of the sensor, but not the readings? I have stock engine on CT9 and am just going to up the boost to 1 bar. I don't like the idea of making a hole to my powergetter, aaargh. Quote
monty1991 Posted February 26, 2013 Posted February 26, 2013 i reckon it wont get a reading that close cause it will be just flames lol.. id drill a hole back where they reccomend Quote
Asad Posted February 26, 2013 Posted February 26, 2013 (edited) on a starlet the sensor should go were the engine block ends and before the gear lever iirc @ the 10/11 o`clock position or the 2/3 o`clock position which ever is easier putting it in the decat will ruin it in a short period of time, price up a sensor lol that itself should put you off installing it in the decat Edited February 26, 2013 by Asad Quote
whitestar Posted February 26, 2013 Author Posted February 26, 2013 What about the OEM sensor? It's right after turbo and it's fine. The second bung is atleast 20-30cm lower. Damn, really don't wanna make a hole to my awesome fujitsubo! Quote
whitestar Posted February 26, 2013 Author Posted February 26, 2013 (edited) Oh I ment the second bung on my decat! The bung on cat is very close to turbo and that's a lambda. Edited February 26, 2013 by whitestar Quote
Sefton-EP91 Posted February 26, 2013 Posted February 26, 2013 I am going to be fitting mine in the near future and hoping to be getting a buddy club spec 2 exhaust with ct9 power up kit. But am also in this situation as to where do I put the sensor? Quote
Flaminsam Posted February 26, 2013 Posted February 26, 2013 Worked fine on charls car in the second hole on the j performance down pipe. And flames? If I recall if the engine is running rich there should be no oxygen to burn? Any car with flames either has a ignition problem or a leaky/blowing exhaust. Quote
