russ78 Posted March 11, 2013 Share Posted March 11, 2013 when I finish forging my engine I gotta run in it , can I run my setup on stock boost while I run it in ? which would be a WEPR TD05 ext wastegate on stock boost or would I be better off running my old setup to run in a CT12 Hybrid with a custom mani and zisco decat on stock boost ? Quote Link to post Share on other sites
JordanEP91 Posted March 11, 2013 Share Posted March 11, 2013 I don't see why you can't run your set up on standard boost, just try and keep the revs down! Quote Link to post Share on other sites
LeeG Posted March 11, 2013 Share Posted March 11, 2013 just run the td05 on stock ecu at 0.6 bar of boost and it will be fine, done that with mines. Quote Link to post Share on other sites
AdamB Posted March 11, 2013 Share Posted March 11, 2013 As long as boost pressure is below fuel cut you should be fine. Although I would probably say run a little under 0.6 bar just to be safe.Don't be a pussy with the engine either, give it some stick and put it under load. It will be within the first 20 miles or so if anything bad is going to happen. Quote Link to post Share on other sites
Bean Posted March 11, 2013 Share Posted March 11, 2013 ran my 5e in with a vf35 it had boost through it in the first mile. not loads mind lol Quote Link to post Share on other sites
Starbuck Posted March 11, 2013 Share Posted March 11, 2013 I ran td04 on mine at no more than .2 / .3 Quote Link to post Share on other sites
russ78 Posted March 11, 2013 Author Share Posted March 11, 2013 On 3/11/2013 at 6:50 PM, Bean said: ran my 5e in with a vf35 it had boost through it in the first mile. not loads mind lol was that at stock boost mate ? Quote Link to post Share on other sites
russ78 Posted March 11, 2013 Author Share Posted March 11, 2013 On 3/11/2013 at 6:53 PM, Starbuck said: I ran td04 on mine at no more than .2 / .3 do you think you was over cautious or would you recommend that sorta boost ? Quote Link to post Share on other sites
jayc-glanza17 Posted March 11, 2013 Share Posted March 11, 2013 russ, u got yur old ct9 set up??PM me if yu need any advice, i ran my forged lump in hard. Quote Link to post Share on other sites
Browner Posted March 11, 2013 Share Posted March 11, 2013 Stick a rev limiter on it. I ran mine in on a 4000rpm rev limiter Quote Link to post Share on other sites
