Light on the unit only works when the bee r is hitting the limiter that has been set on the controller.
When i turn the rev 1 and rev 2 dials it flickers on every now and again
Also i havenet connected the white wire to the handbrake will this make any difference
I would take it not working as a sign.All they do is break engines!
Yeah ive heard all the bad rep on them but i still want it on the car and working
Some one must have fitted one too a glanza ?
You need to wire the white cable to the handbrake. This is how the Bee*R know when or when not to cut spark.
Try that then set all the knobs on the Bee*R to 2 or 3 and tune it from there.
My personal recomendation it that you do not let the Bee*R interfere with your upper rev limit while driving. EG: set it at like 10k revs so it will never come on.
This way it will only cut spark while handbrake is on.
I think Rev 1 is while handbrake off and rev 2 is while handbrake on.
MD
MD
Thanks buddy ill give that a try now
Another thing...
Did you get your Bee*R new or used?
There should be 2 loops of wire coming out of the side of the unit. They determine whether it is used with a 4 + 6 cylinder and rotary engines. Make sure the one for 4 cylinder is cut. (Grey wire)
Here are the levels of cut for rev 1 and 2:
0 2500
1 3000
2 3500
3 4000
4 4500
5 5000
6 5500
7 6000
8 6500
9 7000
A 7500
B 8000
C 8500
D 9000
E 9500
F 10000
Edited by NippyNippon
Number 3 ie the gain is what causes the cut the spark, the bigger the number the longer the cut in spark. Set gain to 3 and the rev one to 3 and it should start poppin, if it does then just set it to 8 or 9.
Also bee r won't work if anyone of the knobs are at zero.
Just tried that there and still no go:( are my wires in the righ places ?
59374588-EB6F-4049-B226-954559ABF98E-125
I can't remember where the wires go or where I found my wiring diagram on the net. Or the bee r you've bought f&@ked.
Well ive tried a few different earths ive checked this wiring diagram against an ecu pinout and everything matches up, number 3 on the 26 pin plug is the igf which is where the yellow wire is meant to go and number 4 on the 26 pin plug is the NE (part of the iia) so it must be the unit ive sent a message to eclipse performance where i bought it from see if they get back too me
