gaz Posted August 16, 2007 Posted August 16, 2007 Found this, but havnt read it.http://www.focusfanatics.com/howtos/enginebay_painting/ Quote
Glanza_Ragger Posted August 17, 2007 Posted August 17, 2007 Thats handy bud, should be usefull for spraying some of the parts..Seeing as they are quite boring and...black. Quote
StarletRick Posted August 17, 2007 Posted August 17, 2007 best thing for painting the engine (the metal parts that is) is caustic soda. it just rapes everything. wipe it off and youre ready to go. it gets every type of dirt off you can imagine. Quote
Glanza_Ragger Posted August 30, 2007 Posted August 30, 2007 best thing for painting the engine (the metal parts that is) is caustic soda. it just rapes everything. wipe it off and youre ready to go. it gets every type of dirt off you can imagine.Caustic Soda? Whats that lolI normally use Gunk to degrease parts i wanna paint, but its not the best stuff in the world and its pretty expensive. Quote
keirz Posted August 31, 2007 Posted August 31, 2007 i just used wd40. that worked quite well for cleaning the rocker cover. Quote
lobotomy Posted August 31, 2007 Posted August 31, 2007 Caustic Soda?You usually use it to clean the inside of your cooker... smells vile, you shouldn't really breath in the fumes either! Quote
Glanza_Ragger Posted August 31, 2007 Posted August 31, 2007 You usually use it to clean the inside of your cooker... smells vile, you shouldn't really breath in the fumes either!Ahhh i know the stuff!Yeah the fumes choke you up instantly.Nasty smelling stuff, but i may give that a go next time.Does the stuff damage paintwork ? Quote
