hello i have springs -40mm in my glanza 16" et35 with tires 205/40 will be ok? or better 15' et35 with tires 205/45 ? Maybe some other suggestions on the other ET? sorry for my english :) thanks Sylwek
The normal size is 15x6.5 et38
This is the common alloy wheel size with 195_45_15 or 195_50_15 tyres
With other sizes you might need a 'adjustable panhard rod' or carry no fat chicks
I have 16x7.5" ET35 rims and 195/40 tires and they do not rub at all. I don't have a panhard rod. I had 205/45/16 on my NA starlet back in the days and it was pulling quite alot if there was worn grooves on the road. I'd really recommend to have max 195 tires if you're having it as a daily driver (you can get wider drag tires for the strip if needed :D). I don't know about your roads in poland but our roads have quite bad grooves on the roads as it's quite common to use studded tires in the winter time.
Edited by whitestar
