Dan Barnes Posted April 10, 2013 Posted April 10, 2013 Been told i need an oil filter cup to make it easier to remove my filter when i do my serviceIs this the correct one?http://www.ebay.co.uk/itm/Oil-Filter-Wrench-Cup-65mm-14-Flu-Toyota-GM-3-8-Drive-/260760509592?pt=UK_Hand_Tools_Equipment&hash=item3cb6899c98Cheers Dan Quote
Arnold Posted April 10, 2013 Posted April 10, 2013 Just stick a screwdriver through it and twist it off Quote
Arnold Posted April 10, 2013 Posted April 10, 2013 Depends on your set up, but no it is a bit tricky. Quote
Dan Barnes Posted April 10, 2013 Author Posted April 10, 2013 Just had a look underneath, can get to it easily :-) jus hope all goes to plan lol Quote
StarletSr? Posted April 10, 2013 Posted April 10, 2013 Depends if its on tight or not but yea screw drivers cheaper ;) Quote
daniel_g Posted April 10, 2013 Posted April 10, 2013 Get an oil filter claw. So much better than a strap or a cup. Quote
Dan Barnes Posted April 10, 2013 Author Posted April 10, 2013 Think ill just use hammer and screw driver and go from the underneath :-) and pray it spins off lol Quote
Starbuck Posted April 10, 2013 Posted April 10, 2013 Use your hand.... With rubber grip gloves. Quote
