Starlet SR Posted April 11, 2013 Posted April 11, 2013 Could be tempted by a 6 speed myself in the future ! Quote
Amjad Posted April 12, 2013 Posted April 12, 2013 I would love a 6th purely for motorway but I like the long gears in my GT Raffa has a G6 box with an LSD I believe, different bolt pattern to the turbo ones Quote
Addymk2 Posted April 12, 2013 Posted April 12, 2013 Theres a detailed spec on here somewhere (I'll search later) but the final gear on the 6 speed box is almost identical to that on the 5 speed box. You get no added cruising benefits just a shorter stack from 1st through to 5th. Quote
Addymk2 Posted April 12, 2013 Posted April 12, 2013 http://en.m.wikipedia.org/wiki/Toyota_C_transmission#section_2The C56 is the box fitted to a Glanza0.815 5th gear ratio4.312 Final drive ratio The C60 is the 6 speed box0.725 6th gear ratio4.529 Final drive Using this calculator:http://www.teammfactory.com/gearcalculator.php?kmh=0&tirewidth=195&tireprofile=55&wheelsize=15&tirediameter1=23.44&maxrpm1=7500&finaldrive1=4.312&gearratio1=3.23&gearratio2=2.105&gearratio3=1.458&gearratio4=1.107&gearratio5=0.815&gearratio6=0&trannytype=&tirewidth2=195&tireprofile2=55&wheelsize2=15&tirediameter2=23.44&maxrpm2=7500&finaldrive2=4.529&gearratioa=3.23&gearratiob=2.105&gearratioc=1.458&gearratiod=1.107&gearratioe=0.725&gearratiof=0&trannytype=&tranny=Calculate+Transmission+1+%26+2the 6th gear is slightly longer, only a smidgen. Say your cruising at 80mph with the 5 speed box, on 15s in 5th with 195x55 tyres you will be cruising at around 3950RPM. At 80mph with the 6 speed box again on 15s in 6th with 195x55 tyre you will be cruising at around 3650RPM. Not a bad little difference. But then with the tiny 1st couple of gears in the 6 speed box is it going to drive you mental shifting all the time lol although 2nd gear launches would be reasonable Quote
PaulStarletSR Posted April 12, 2013 Posted April 12, 2013 Don't quote me on this but I think they're restricted power wise to 250bhp area before they're at risk of spewing. I may well be wrong though. They're corola gearbox's rubbish. there is no hard evidence of this. capable of much more than that! the 6 speed boxes r closer ratio than normal, not by much. also its never a bad thing havin a 6th gear, il be getin 1 for my conversion Quote
Addymk2 Posted April 12, 2013 Posted April 12, 2013 rubbish. there is no hard evidence of this. capable of much more than that! the 6 speed boxes r closer ratio than normal, not by much. also its never a bad thing havin a 6th gear, il be getin 1 for my conversionNo hard evidence but big power starlets have a habit of stripping standard gears, the 6 speed box has thinner discs? (Terminology is shocking there but I think you know what I mean!) Quote
kavan-k Posted April 12, 2013 Author Posted April 12, 2013 What was curiosity has now turned into pure temptation! My build might just get a 6 speed box! Providing i can give it a good diff! Need a 100% proof you can tho! Quote
Addymk2 Posted April 12, 2013 Posted April 12, 2013 100% proof you can fit a diff? You can, well, the diffs have the same part number http://www.ukstarletowners.com/topic/58228-for-sale-6-speed-gearbox-for-ep82-ep91/#entry745975 Quote
kavan-k Posted April 12, 2013 Author Posted April 12, 2013 i think im gonna go for it! Wonder if the box is hard to source! Im excited haha Quote
Amjad Posted April 12, 2013 Posted April 12, 2013 Bolt pattern is different to FTE boxes though so diff's are different? Quote
kavan-k Posted April 12, 2013 Author Posted April 12, 2013 Right enough :/ someone on the forum must have a 6 speed with a diff! Quote
kavan-k Posted April 12, 2013 Author Posted April 12, 2013 Just read on the above ^^ mike@td said they are the same! Quote
