Hi guys and girls :)
need a passenger side hub NON-ABS with a good wheel bearing for uk spec starlet, 1998.
I dont know if they are the same as glanza or not. If somebody knows please tell me.
looking to have it delivered unless nearby
thanks
Edited by 5T4R7ET N/A
I have a Uk spec one I have just removed from mine the bearing seemed ok when I removed it, The glanza ones do fit but the hole for the track rod end is drilled in a slightly different place so it puts the tracking way out but it can be adjusted back ok, Im running glanza ones on mine now.
