Help ordering a part from Camskill
Hey guys,
I've had a knocking noise coming from my outer CV joint so been looking to replace both driveshafts fully to be safe. Then i was thinking if i was to replace both inner and outer joints on both shafts it'd be better then risking second hand shafts which could have the same problem,,,
Could anyone shed any light whether this item on Camskill is both inner/outer joints, so one side complete etc? Their pictures say inner and outer but item title says outer? And also the 23/30 splines...
http://www.camskill.co.uk/m19b0s1304p9670/TOYOTA_STARLET_TURBO_%28EP82_EP91%29_-_SERVICING_PARTS_TUNING_SPARES_and_SERVICE_ACCESSORIES_-_Outer_CV_Joint_Kit_-_23_30_Splines_-_Toyota_Starlet_Turbo_EP82_EP91
Many thanks, Tobie
Ps i need this sorted so i can make it to japfest ;)
If the CV joint is knocking ( when you turn your wheel, mainly on full lock) then the item you are looking at, CV joint 23/30 is what you need :)
My car had the same problem when I bought it. Got 2 new joints for each side from cam skill and had no problems since
