white-gt Posted April 17, 2013 Posted April 17, 2013 Hi guys i had a mate try and change the fuel filter but he said the bolt just wont move to the point its starting to round off and theirs only so much pressure to use, im told this is a common issue. anyone got any advice? the car has done about 100k miles and i dont think its ever been done, is it worth doing or what? thanks Quote
ryan lang Posted April 17, 2013 Posted April 17, 2013 alot of people who have them done previously mess them up and cross thread them. i had the same thing in the GT Quote
Dan Barnes Posted April 17, 2013 Posted April 17, 2013 Tried doing mine on monday when i serviced car, would not come off :/ Quote
white-gt Posted April 17, 2013 Author Posted April 17, 2013 Seems a right tart! So Whats the options? Quote
Dan Barnes Posted April 17, 2013 Posted April 17, 2013 Hammer ! Just kidding, i need an answer on this too Quote
Mr. Chem Posted April 17, 2013 Posted April 17, 2013 (edited) Decent quality spanners are a must! The is a larger nut welded to the bottom of the fuel filter you can hold iirc its a 19mm. I have just done this, and it was such a pain, but hopefully this will help. When undoing the top bolt, I held the bottom with a spanner. Use plenty of penetrating fluid like Plus-gas not wd40. When undoing the lower nut, as it was just me I did it from underneath, holding the larger nut with a spanner on my left, and the smaller union nut on the right behind the engine with my right. Then its just brute force and ignorance. Undo your petrol cap before you start though to release the pressure, otherwise fuel pisses everywhere. Edited April 17, 2013 by Mr. Chem Quote
Sefton-EP91 Posted April 17, 2013 Posted April 17, 2013 Mine was way too tight! Just some strong arms and decent spanners does the job Quote
whitestar Posted April 28, 2013 Posted April 28, 2013 I gave the lower nut a bit heat with a heat gun and that helped alot. Be careful though, don't spil fuel in the heat gun! Quote
