Hi
My Starlet SR appears to have the washer function the wrong way around ie pull wiper arm toward you does nothing unless rear wiper is on then it actives washer , and rotate arm end and it actives bonnet washer, is this correct? if not how do i correct the wiring for it.
Many thanks
Ric
ok thanks will check, where is ws pump? i cant see one, hope it not hidden away in wheel arch :-)
I've had too much wiring on my mind! First post was the complicated way. Swapping the pipes rounds is the easy way :)
Tbh it only just clicked a minute ago when it was mentioned two pipes on one pump. I was in the same mind set over thinking things then was just like ADUH.... Swap pipes lol
Edited by morgey
I went to unplug the one on my old loom on the GT and it just completely fell apart, wouldn't unplug and didnt react well to a reasonable amount of force lol.
Also, by the looks of it the new loom i have must have had the washer bottle relocated to the boot because there is no plug where there should be haha.
Hate starlets.
