Beastmode panda Posted April 20, 2013 Posted April 20, 2013 Really need some quick help if at all possible guys! I've just gone externally gated, I've had to borrow my mates shitty ebay wastegate until my tial arrives. So everything is plumbed it correctly to my understand, went for a drive and no boost until like 5k revs????? Is doesn't flutter or anything what so ever when I let off the throttle or change gear???? What is wrong? I've got a gizmo boost controller and the blue wire popped out the pin today some how and I put the wire back, unsure if this would be the problem though as I've tried a vacuum from the turbo to the inlet of the wastegate and it's still exactly the same? Pleeeeease any help.. Quote
AdamB Posted April 20, 2013 Posted April 20, 2013 You sure you got the vac lines the right way round on the gate? Not familier with how to setup egay specials though. Quote
akyakapotter Posted April 20, 2013 Posted April 20, 2013 Be very careful mate I wouldn't drive till you get your tial. my mate used a crap eBay one blew a hole in his block with in 5mins of putting it on waste gate didn't open spiked to like 3bar. Quote
Beastmode panda Posted April 20, 2013 Author Posted April 20, 2013 I did it how the gizmo instructions said online man, I've tried them both ways now. I'm right in thinking that when I rev the car it should flutter right?? It doesn't even do that Quote
Beastmode panda Posted April 20, 2013 Author Posted April 20, 2013 On 4/20/2013 at 4:49 PM, AdamB said: You sure you not got a vac leak? 110% man, brand new vacuum lines and the car was running 100% perfect 2 days ago. Quote
turbo Grant Posted April 20, 2013 Posted April 20, 2013 Is the waste gate blowing at all in idle? Peoepe forget to put the valve seat in some times Quote
Beastmode panda Posted April 20, 2013 Author Posted April 20, 2013 Umm im not too sure dude, what does the wastegate valve seat look like lol?I just googled it, no bro that part is not in? it's sitting on my side top lol, does that make a difference?? Quote
keirz Posted April 20, 2013 Posted April 20, 2013 wastegate will make no noise. that's not where the flutter comes from loltrial it without the boost controller. just go turbo to side port and see when the boost comes in. you will only be wastegate pressure but at least it will give and idea as to if its the wastegate at fault or your boost controlleror put the seat in! Quote
akyakapotter Posted April 20, 2013 Posted April 20, 2013 On 4/20/2013 at 4:57 PM, turbo Grant said: Is the waste gate blowing at all in idle? Peoepe forget to put the valve seat in some timesI didn't do that Quote
turbo Grant Posted April 20, 2013 Posted April 20, 2013 On 4/20/2013 at 5:00 PM, Rbz. said: Umm im not too sure dude, what does the wastegate valve seat look like lol?I just googled it, no bro that part is not in? it's sitting on my side top lol, does that make a difference??Yes mate it might work a bit better with that in haha Quote
Beastmode panda Posted April 20, 2013 Author Posted April 20, 2013 It worked haha! I'm a narna . Thank you grant I totally forgot about that part laying on my side Quote
turbo Grant Posted April 20, 2013 Posted April 20, 2013 It's easy done if it not kept together. Pulls nice now then Quote
Beastmode panda Posted April 20, 2013 Author Posted April 20, 2013 On 4/20/2013 at 6:11 PM, turbo Grant said: It's easy done if it not kept together. Pulls nice now then only went down the road but yeah it's 10x better, will have a proper drive later thanks man Quote
akyakapotter Posted April 20, 2013 Posted April 20, 2013 On 4/20/2013 at 6:37 PM, Rbz. said: only went down the road but yeah it's 10x better, will have a proper drive later thanks manJust an Emb needed now Quote
Beastmode panda Posted April 20, 2013 Author Posted April 20, 2013 On 4/20/2013 at 6:37 PM, akyakapotter said: Just an Emb needed now You will be the death of me I swear! Haha.. Quote
