I need a hole type actuator ASAP that will fit the pic below as my hks one is clearly no where near the right one
B173CEC8-622C-40EB-9784-936D55B1B29C-422
If it makes any odds this is a speed vision 2 hybrid ct9
I had this issue when somone wanted to fit a ct9b to ther ep82 which already had a hole type HKS actuator on the original CT9a.
The ct9 b has a hole and the ct9a has a pin.
I used a high tensile screw to feed through the hole and put a nut on the end of it.
It still works fine after 2 years.
Or you can drill the pin out on the actuator arm so it fits onto the pin on the turbo and you should still be able to put the c-clip on it
