So I turned the electrics on in the car for the first time in 8 months to check the lights, everything works bar the headlights? The fuses are all fine and the wiring looks ok too, don't know. What else the problem could be?
failing all that, try your fog light switch.
mine died and killed all my lights as its on the same circuit.
Phil.
This sorted it :) now indicators don't work :(
  • 2 weeks later...
my headlights stopped working not long ago and my main beam too, under the steering wheel the main plug about 40mm wide has a wire for the lights and mine had corroded and burnt a little but sorted that and now they work :) my indicators stopped working too but that was because i didnt replug my hazard light switch properly :p
