mowgli123 Posted April 28, 2013 Posted April 28, 2013 Is there any guide on how to install a dumpvalve.Got my car running without one. I actually only have the actual dumpcvalve which says "re-performance centre" on it. Any help lads? Quote
davehart Posted April 28, 2013 Posted April 28, 2013 Pretty easy to put on these. Are you running the stock top mount or have an aftermarket FMIC? The topmount, you have to removed the stock re-circulating valve, block up the hole in the EFI pipe (50p coin will do) and place a breather filter on the rocker cover or install a catch can. For the BOV inlet use the line that the stock valve goes into on the inlet manifold. Job done. Quote
mowgli123 Posted April 28, 2013 Author Posted April 28, 2013 Hi man I have a aftermarket front mount intercooler..Not too got when it comes to turbo's so might have to explain in baby language lol Quote
Patches Posted April 28, 2013 Posted April 28, 2013 Put up a pic of your engine bay. Make sure we can see your intercooler pipes clearly. There should be a small tube/or space for one running off the intercooler piping, if u dont have a dump valve chances are its just blocked off at the end. This is where u want to fit yours Quote
mowgli123 Posted April 29, 2013 Author Posted April 29, 2013 http://s1061.photobucket.com/user/mowgli1234/media/59592_10151319935286486_1251886373_n_zpsc8e835f7.jpg.html'> Thats my bay.. Could someone please explain with pictures if they can? Quote
A L 3 X Posted April 30, 2013 Posted April 30, 2013 there looks to be no adaptor for a BOV on your intercooler piping, you will need something like this:http://www.ebay.co.uk/itm/Polished-Alloy-T-Piece-TPiece-BOV-Dump-Valve-Adapter-Aluminium-Silicone-Hose-/330667339255?pt=LH_DefaultDomain_3&var=&hash=item4cfd4f2df7 Quote
mowgli123 Posted April 30, 2013 Author Posted April 30, 2013 Ok if i order that.. What do i do with it and where shall i put it? Noob Quote
TurboTobz Posted April 30, 2013 Posted April 30, 2013 I got the same issue think I'll get my bov welded on though saves messing about Quote
A L 3 X Posted April 30, 2013 Posted April 30, 2013 you'll have to cut the cold side intercooler pipe down, use a silicone joiner either side and then attach your dump valve to that with another silicone joiner lol.... so it fits like this:http://i1031.photobucket.com/albums/y372/tyrondevine/IMG_4137_zps9d08e56d.jpg Quote
TurboTobz Posted May 1, 2013 Posted May 1, 2013 Either that or depending one what dump valve you have or if you have the flange you could have it tig welded on. What ever works for you! Quote
