dazstarlet Posted April 30, 2013 Posted April 30, 2013 I think it would be good to have a section in the td area for issues that people are not sure about. For example I have a grating / chaffing sound coming from somewhere for the first few meters after I set off but then sound goes away. I have no idea if it's engine, gearbox, suspension or whatever. So I'm not not sure which section to post in. An unknown / mystery techie problem bit would be good as a catch all for all those issues people don't know where the problem lies. What do you think? Quote
dazstarlet Posted May 9, 2013 Author Posted May 9, 2013 Maybe it's me. So what forum sub-section do you post about mechanical faults if you don't know what the fault is? Quote
morgey Posted May 9, 2013 Posted May 9, 2013 Just post it in lifestyle general and let one of the mod decide where it belongs. Also if people get to the route of the problem then it can then be moved once its sorted. To me your problem sounds like a brake disc heat/dust sheild rubbing on a disc Quote
rasslenny Posted May 9, 2013 Posted May 9, 2013 was now gona say it sounds like your brake dust shield..... mine bent and was touching the rotor once horrid noise that..... Quote
Addymk2 Posted May 9, 2013 Posted May 9, 2013 I think thats a good idea, you get threads relating to all sorts popping up all over the place! If someone genuineley has no idea whats causing the problem its worth posting it into a mystery section Quote
